Configures the value of PTP delay request interval time to send successive delay request messages when the port is in the master state.
boundary |
Boundary clock instance. |
ordinary |
Ordinary clock instance. |
seconds_log_base_2 |
The log base 2 value of the seconds of the timeout for PTP announce messages. For example, to specify 8 seconds, use 3. The default value is -6, and the range is -7 to 5. |
vlan_name |
VLAN name to which the command is to be applied. |
The default value of the announce delay request interval is log base 2 (-6), or 64 delay request messages per second.
Use this command to configure the value of PTP delay request interval time to send delay request messages when the port is in the master state. The clock port should not have unicast static slaves or masters added to apply the configuration.
Set the delay request interval using log base 2 values. The range is -7 to 5. This command is available only for boundary and ordinary clocks.
The following command configures the delay request message rate of 32/second on the clock port lpbk-gm of the ordinary clock:
# configure network-clock ptp ordinary delay-request-interval -5 vlan lpbk-gm
The following command configures the delay request message rate of 128/second on the clock port lpbk-gm of the boundary clock:
# configure network-clock ptp boundary delay-request-interval -7 vlan lpbk-gm
This command was first available in v 15.1.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
